1 - 2 of 2 Posts
So, I've read that intel's recommending 1.5V for the sb cpus. Problem is, I can only choose between: 1600MHz at 1.6V, 1600MHz at 1.65V, 2250MHz at 1.7V and 1333MHz at 1.5V but without a heatsink. Could 1.65V cause some kind of damage to the cpu, or is it in the tolerated zone?
EDIT: I've also found on intel's site a datasheet that says pretty much the same thing about i5 7xx and i7 8xx processors. Look at the bottom of page 11 (DDR3 I/O Voltage of 1.5 V)
I don't know much about the memory specifications of SB, but from what I've heard, 1.65v should be fine.
1 - 2 of 2 Posts
