Originally Posted by
QuEP
Excellent info Alatar. Now I can clearly see that NOT being able to run dual i7's is the big difference !!
Also the cinebench as means to compare render times has been helpfull (although 10% lower as hoped).
Thanks to you I have found this review that clearly shows the differences under different uses and their benchmarks:
http://www.istorya.net/forums/computer-hardware/485176-intel-xeon-e5-2690-and-e5-2660-8-core-sandy-bridge-ep-review.html
Now it is a no brainer : for multicore rendering nothing beats a dual E5-2687W system , for single core 3D modelling, an overclocked i7 might safe you a few bucks. I need to be able to do both as fast as possible with one system: a dual E5-2687W will be ugly to get financed but will cut down a 2000 hour nightmare render project to a manegable 700 hours. I hope watercooling will quiet down the noise, increase lifetime an hopefully enables to run a single core modelling at 4GHz or slightly higher (a rebuilt on my X5690 still costs 5 to 15 minutes).
MANY THANKS FOR THE HELP, hard to get unbiased help on expensive systems.
