1 - 6 of 6 Posts
Im using P4 2.4 ASUS MB (Via chipset VT8237)
256MB
60GB HD
52x Asus CDrom
SB Live 24 bit
Hard disk is primary IDE, CD rom is secondary IDE masters
I have used old creative and Ectiva sound cards very wel in last years. I gat a SB Live 24bit new card.
I have a dual boot sys, I installed SB drivers in win98se and it worked well. no problem (although sound card specs didnot said its compatible with win98)
then I installed drivers to winXP sp2, it worked well untill i used cd rom.
whenever cd rom is reading data sound gets very distorted (sound is from Hard disk files; mp3 wav, ..). I used different players problem remain,in games the sound distorts when cd runs.
cant play a Audio CD, sound is too distorted.
I have changed the Sb's PCI slot and booted first the problem was gone, then restarted and problem remained.
try with and without that 4pin cable to sound card, no hope
I have questined creative support but no answer.
Please help me !!
I had the same problem with that card, Delete drivers, and boot normally. Its a PCI Plug/Play so you dont need to install any sound drivers. =)
I turned on DMA for CD rom. problem gone !!!
but dont know for how much time it'l last for
anyway thanks very much for help!!!
1 - 6 of 6 Posts
