My writeup on the enthoo pro :
Obviously, this is not an big chassis like the switch 810 and will not fit rads in the same places as the 810. But, the enthoo pro makes use of it's displaced size very well by allowing you to configure most of the case to what you like.
Most of the case can be dismantled for painting but there is some of it that are riveted, for reasons unknown. It should have been screwed in as well.
It looks good, classy and simple. None of the busy looking designs like a HAF Stacker (
Radiator support : Obviously, it won't be so simple since a bottom 240 will slam right into your PSU if you use a 190mm long PSU like I do. Just that 20mm difference in depth makes it pretty much impossible for you to install a 240 rad.
Otherwise, you can always keep the bottom HDD cage if you want to use HDDs like I do and install the 240 without the optical bay on the middle 120mm fan slot, with the other 120 in the area where the optical bay used to be.
Of course, the key points I have to raise is that the Enthoo Pro is well-built and has a PSU cover along with a optical bay AND HDD bay cover which hides up most of what you wouldn't want to see.
Cable management space at 27mm which admittedly isn't the most but there's a bulge in the bottom allowing for even more cable management in the very bottom which makes it far more brilliant than my 810 for cable management which doesn't have much
The doors are hinged like the 810 but doesn't require 1000 pounds of force to pull it out of orbit and doesn't have silly plastic door latches that will break if you open the doors frequently (which I do)
The paint is glossy, which is a shame as that makes it VERY sensitive to fingerprint marks. It's a perfectly smooth finish though and the "brushed parts" are actually plastic! Great.
With only the bottom HDD you can hide the reservoir and pump if you so desire as well.
Actually, the velcro straps for cable management are fantastic.
If I have three gripes with it (which I do) is that the built in fan controller is very weird you can't have it powered from the SATA plug unless you enjoy running fans at full blast which defeats the point of the fan controller. Also mine came broken so I never knew how it reacts to control.
Another gripe is that I can't install a 45mm rad with a single row of fans easily, being that it has only 65mm clearance and it is not offset so it will hit my VRM heatsink and RAM clips on my EX58-UD5.
Of course, the other one is that the built 200mm runs at 900rpm out of the box. It is indeed the very phanteks fan you can buy off the shelf so it's a good fan but it's quite loud and you cannot really have it spin lower than 600rpm easily if you're using voltage resistors. Normally I don't like 200mm fans because there aren't any good ones that I usually know of but I probably approve of this one if there's nothing in the way apart from the screen filter which is great, unfortunately HDD cages is in the way so no.
And also having taken out the PH-F200SP and put in the stock PH-F140XP cooling my R9 280X TurboDuo is a lot easier.
So now, main things I would like to see phanteks improve on, extending the top of the case by at least 10mm for more rad clearance and a rough paint coat would be nice. Glossy is nice to look at but not nice once you have your fingers on it
Nonetheless, it's going to cost 99$ here and fit and finish is fantastic. Only 99$ for a case this customizable is definitely a winner. Is it a perfect case? I don't think so. Is it a great modder's case? Yes!
