1 - 20 of 168 Posts
The Fabricat0r
Final pictures!
Hello everyone!
It's been a while since I posted a project on OCN so I figured I should share something new I am starting on.
It's a mITX mod inspired by some chrome hubcaps I picked up. These particular hubcaps are nicknamed "Baby Moons", hence the project name.
I'm not a 3D wiz but here are some basic sketchup models to get an idea.
The hubcap/side panels are ~10.5", just big enough to fit a mITX mobo inside the diameter.
Here's the hardware I will be using:
Asrock H77M-ITX
i5-3570
2x4gb Corsair 1600mhz
Intel X-25M 80gb SSD
150W picoPSU
The Fabricat0r
Discussion Starter #2
Obligatory materials shot.
Making the outer shell comes first, starting with a 1/8" round-over using a router.
Milling an opening (to be explained later) with my new-ish toy.
You like my budget DRO
Using a 3/16" ball mill I started cutting the groves.
10 down, 104 to go
. I'd kill for a cnc router. The groves will make it much easier to form the shell and I think will look good.
I went ahead and did a brushed finish just in case anodizing can be fit into the budget. If not, it'll get some flat black paint eventually.
That's all for today. Thanks for reading!
Whao! Unique shape for a casemod.. Circles are hard.... :L So the way the casemod seems to look, are both sides curved hubs or just 1 side? Kinda reminds me of Spaceballs except for the chrome finish, Subbed!
The Fabricat0r
Discussion Starter #6
Both sides will be the domed hubcaps.
I'd love to give a decent update on my progress, but after three hours I'm still far from done milling the reliefs.
It'll probably be three more hours...
Oh i see, yeah it really pains to not have a CNC mill.. Luckily I live near a pretty industrial part of Texas and can get my stuff sent in and done quick.. However I doubt I have the will to go do something as complicated as this. :/
The Fabricat0r
Discussion Starter #10
The Fabricat0r
Discussion Starter #11
I made some wood blocks to do some fine tuning with the help of a mini sledge.
http://picturepush.com/public/13492307
What I haven't shown is that I messed up on one of the grooves and it ended up being ~0.025" too deep. This made it a weak point and I had trouble with it bending more readily than the others which didn't end well.
http://picturepush.com/public/13492308
http://picturepush.com/public/13492309
Time to make a new one.
To make the grooves in the shell I used some two flute HSS mills. To makes things go a bit faster I'm going to order some four flute coated bits and try it again. Because of the small diameter I think I can move up to four flutes and not push my mill too much. I figured something would happen so I bought enough material to make a second shell. The next one should at least be a little easier to make
The Fabricat0r
Discussion Starter #13
I've been experimenting with annealing and it seems to make a difference. I took the broken off piece and heated it with a propane torch. Google taught me that if you mark the backside with a permanent marker, it will fade when you reach the correct temp for annealing. Once it cooled it did seem a good bit easier to bend. Mind you, it still wasn't very easy but I think I will try it after I machine the next piece. Strength isn't a huge issue so hopefully I can get by without tempering it when I'm done.
The Fabricat0r
Discussion Starter #14
To redeem myself from yesterdays complete failure, I started work on the uprights for the base. Using some 1"x2.5" flat bar, I ended up with this...
http://picturepush.com/public/13497119
http://picturepush.com/public/13497120
http://picturepush.com/public/13497121
http://picturepush.com/public/13497122
http://picturepush.com/public/13497123
http://picturepush.com/public/13497124
http://picturepush.com/public/13497125
Quite a bit to go with them, but I'm pleased. I also ordered more ball nose bits, should be here soon so I can get back to the shell.
Thanks for looking!
The Fabricat0r
Discussion Starter #17
Good news! I'm finally back to where I was two weeks ago.
http://picturepush.com/public/13553828
http://picturepush.com/public/13553829
http://picturepush.com/public/13553830
http://picturepush.com/public/13553831
http://picturepush.com/public/13553832
There's still a bit of a flat spot I only noticed just now looking at the pics. I also need to sand the inside and smooth out all those little bends.
But this one came out almost perfect and it only took three attempts
. The annealing helped a ton, you can still see the faded permanent marker I used as a temp indicator. Hopefully I'll have some more updates soon!
Tech Enthusiast
Definitely in for this... wish I had a mill.
1 - 20 of 168 Posts
