1 - 14 of 14 Posts
Project Riesen-
Custom 80/20 case build constructed with 1" x 1" and 1" x 2" T-slot aluminum.
My first custom case build.
Dimensions will be 36" x 24" x 50"
CASE PARTS
4 80/20 1010 T-SLOT BLACK 145" 580" TOTAL $213.00 (RECEIVED)
1 80/20 1020 T-SLOT BLACK 145" $86.32(RECEIVED)
2 80/20 Inc T-Slot Tools 10 Series Acess Hole Drill Bit Part #6115 N $6.60 (RECEIVED)
1 80/20 Inc T Slot Access Hole Drill Jig 10 S 6131 N $36.20 (RECEIVED)
4 80/20 Inc., 2066, 10 Series, Door Captivating Heavy Duty Hinge Assembly (ORDER FROM ?)
8 4041 Squared Tri-Corner Connector 1" $100.00 (RECEIVED)
FEET? 2829 Rubber Door Seal PAGE 406 (NEED TO ORDER)
FEET? 80/20 Inc., 2816, 10 Series, orange Economy T-Slot Cover (ORDER FROM AMAZON)
16 80/20 8020 EQUIVALENT Anodized Aluminum Panel Mount Block 10 Series 2427 $64.00 (ON ORDER)
30 80/20 8020 EQUIVALENT - 3381 - Blank End Fastener Assembly for 10 Series $28.50 (ON ORDER)
25 80/20 Inc., 3017, 10 Series, 1/4-20 X 1" Low Head Socket Cap Screw (LHSCS) $13.25 (ON ORDER)
4 80/20 Inc., 10 Series, Part# 2131, 2" x .5" x 2" Base Plate with 3/8-16 Tap Thru in Center $54.60 (ON ORDER)
4 DOUBLE WHEEL CASTERS JACOB HOLTZ 155-2XPU-29-WB Dual Whl Swvl Cstr,Brk,150 lb,1-1/2 In. $20.00 (ON ORDER)
GET PIECES CUT THEN FIGURE OUT PANEL SIZES
1 CASE LABS TX10 4U Quad PSU Mount
2 PSU Covers Ventilated ($10.95)
DONE
2 Koolance 3x140mm Fan Radiator Shroud, Black
DONE
4 Watercool MO-RA3 360 Wall/Case Holder
WATER COOLING SYSTEM STAGE
DONE
2 Aquacomputer Aquastream XT USB 12V Pump- Ultra Version
DONE
2 Aquacomputer Decoupling for the Pump Mounting, Extra-Soft Yellow Rubber Buffers
HAVE 1 NEED 1
1 Aquacomputer Aquaero 6 PRO USB Fan-Controller, Grafik-LCD
HAVE 1 NEED 1
2 Aquacomputer Aquaero 5 and 6 PRO Aluminum Faceplate - Black (53091)
HAVE 3 NEED 3 MORE
6 Aquacomputer Poweradjust 3 USB - Ultra-Series
DONE
2 Aquacomputer Passive Heatsink for aquaero 6, RED
DONE
1 Aquacomputer Mounting Plate for Poweradjust 2 USB - Black Anodized Aluminium
AQ-53124 Aquacomputer Aquabus Y-Cable 4-Pin
Aquacomputer Aquabus Cable 4-Pin
DONE
Aquacomputer flow meter cable 3-pin
DONE 6 NEED 2 MORE
8 Aquacomputer Temperature Sensor - Inner/Outer Thread G1/4
DONE 1 NEED 1
1 Aquacomputer Flow Sensor 'High Flow' G1/4 for Aquaero 4/5/6, Aquastream XT Ultra and Poweradjust
DONE
2 ICY DOCK ToughArmor MB994SP-4SB-1 4x2.5" SATA HDD Hot Swap Mobile Rack
NEED
2 ToughArmor MB994IPO-3SB 2x2.5" SAS/SATA HDD + 1x Slim ODD Rack
DONE
4 Watercool MO-RA3 360 PRO - Stainless Steel
DONE
4 Watercool MO-RA3 360 Blende Classic - Black Chrome PART NUMBER WC-22051
NEED
CPU BLOCK?
1 X EKSUPREME HF?
1 X XSPC RAYSTORM?
DONE
1 EK EVGA 780 Classified (and 780 Ti Classified) VGA Liquid Cooling Block - Nickel + Acetal (EK- FC780 GTX Classy - Acetal+Nickel) ex-blc-1556
MOTHERBOARD
1 EVGA X99 Classified
http://www.evga.com/Products/Product.aspx?pn=151-HE-E999-KR
1 POWER SUPPLIES?
EVGA SuperNOVA 1600 G2 Power Supply
1 EVGA SuperNOVA 1300 G2 Power Supply?
NEED 30 MORE
16 Silverstone 180mm Fan Grill & Filter
Done
2 5 x 5.25 optical drive cage
Phobya WaCoolT UltraBig Watercase - 5 1/4" Panels PH-75138
Base.
Bottom of base with caster plates on.
Base with Radiator platform installed.
Two MORA-360 radiator covers installed and secured in the frame work.
Mock up with two MORA-360's.
working on right side of chamber number one / bottom of chamber number two.
Mounts put on radiators.
Bottom of chamber three.
Top finished.
View from rear of case.
Rear of case and right side view.
Right side.
More to come!
Lock Down
Discussion Starter · #2 ·
Getting panels cut to fit.
Cutting plate aluminum
Jig saw didn't work out to well takes to long aluminum builds up. I got a Tenyru 7-1/4 skill saw blade and it cuts that 3/16 plate aluminum like butter.
Subbed! this is gonna be one monster of a build! make me think of doing something like this involving old vacuum tubes ALA eniac
subbed to see how this monster turns out. It looks like it's going to look a bit like a CaseLabs TH-10, only bigger, which is hard to imagine lol
Discussion Starter · #8 ·
That's why I made it bigger
I was starting to think no one was interested and was going to stop posting.
Lock
1 - 14 of 14 Posts
