I have been discussing this build for a while over on my other G5 build log but now that I have started to build it I figured it needed its own build log so here goes.
The idea of this build is to have a small robust computer that I can use at school and bring to and from school with no worries so that rules out fancy water cooling so I will just be using an H60 for cooling. Hardware comprises of
i7 4670K
Gigabyte GA Z87N wifi
8GB Corsair vengeance RAM
120GB Samsung EVO SSD
3TB Seagate HDD
HD PLex 250W power supply
The idea for the case came from the heatsink cover panels that I removed from my G5s, my brother pointed out that they would make cool side panels for a case and hence this mod was born.
The overall dimensions will be 190mmx180mmx235mm
Here are some renders of the case
i7 4670K
3TB Seagate HDD
