Welcome to my very first SCRATCH BUILD!
I hope I can produce a decent quality product as I have seen tons of insanely good works of art created by many more experienced builders, but it all takes practice and I feel that I can pull this one off.
My concept is a small end table made from 1/2" oak plywood that will be 24" wide x 18" deep x 24" tall (if I am remembering correctly) and it will contain 2 drawers and an open bottom cubby. The top surface will also have a plexi or real glass square to view inside.
I plan to try and build the end table without the use of any screws, instead I will use wood glue and dowel rods.
The top drawer will house the majority of the PC, but the PSU and optical drive will actually be hanging underneath the top drawer and extend into the space of the bottom drawer. The lower cubby will likely house my wireless aio printer.
To keep it clean and simple I am going for a white and black theme.
A bit of background:
I have had the idea for quite some time now, but I don't have a way to work on it at my current apartment.
I have spent a lot of time modeling it in Inventor and making changes and all of the real work I get done is when I visit my parents (most of my large tools are there plus the space to work).
It's going to be awhile before I visit them again so there is down time in between trips. I hope to get as much done as I can every time I visit, but not at the expense of poor craftsmanship.
With the down time I try to map out the little details and still have a few odds and ends to purchase. I am also considering trying to work on little pieces at my place and not make too much mess or noise, every bit should help.
*Edit: I now have some pieces at my apartment and am committed to work on them as much as possible so I can get this build done sooner*
This PC is more of a budget build that I put together a year ago when I had the initial design drawn up and hoped to be constructing this desk much sooner. Luckily the sacrificial case I bought has worked well to keep things running and usable all this time.
It is a low use secondary PC that currently gets used for Netflix/Hulu in my bedroom on random nights, but was also planned to be an extra mediocre gaming PC if I have anyone over that wants to mess around on something.
It has also been fun to tinker with Linux Mint for a short while as I have never tried a Linux OS before, but I haven't really put any time in learning how to use Linux so I have only scratched the surface there.
I installed the Windows 10 Technical Preview on a partition to see what it was like before launch and have since been running the now live Win10 Pro that it upgraded into and have been using that the majority of the time I boot it up.
Lastly, I was intrigued by the overclockability of a budget chip (G3258) and wanted to give that a try so I had to get the remaining components to allow me to test out the chip.
Unfortunately since it is a budget build, I had to go with a basic air cooler. I would like the aesthetics of an AIO and will hopefully swap one in later, but for now this will do.
I would really like to have tried out a true water cooled setup since I haven't had the luxury of one yet and they look awesome, but that certainly wouldn't have been cheap.
Maybe just a simple CPU loop can be put in some day, but then again my main gaming rig would likely be a better choice to spend any money on water cooling.
If you happen to come across a closeout deal of WC parts at insane discounts, let me know and maybe I will squeeze it into the build
The Components:
CPU - Intel Pentium G3258
Mobo - Asus Z87 Gryphon with Thermal Armor Kit
Ram - 8GB HyperX Fury 1866 (White)
GPU - XFX R7 250X (received from an RMA of my old GTX260 that died)
PSU - Corsair CS450M
Cooler - Cooler Master Hyper T4
Wireless AC Card - TP-LINK Archer T9E AC1900
HDD - 150 GB 10k rpm WD VelociRaptor (from my very first PC)
SSD - 250 GB Samsung 840 EVO
Case - Custom Wooden End Table (with a mobo tray from a sacrificial case)
Intake Fans - 2x 140mm Phanteks PH-F140MP
LEDs - CableMod WideBeam LED Strips Thanks to their event on OCN and sponsorship of my build.
Custom Sleeved Extensions - CableMod ModMesh (Black and White)
Sleeved SATA Data Cables - CableMod ModMesh (Black and White)
Renderings of the End Table:
The following are from Autodesk Inventor, I haven't really used the realistic rendering side of it much so they images probably aren't the best, but they get the point of the design across.
Top Drawer:
Bottom Drawer:
Base Cabinet:
Assembly:
Final Comments
I think this will be a lot of fun and turn out to be a pretty slick and unique build. I welcome anyone to follow along with me and provide feedback, ask questions, or just enjoy the journey.
It'd be great to see that I am bringing some enjoyment to my followers and even better if I end up inspiring someone to give a custom build a try.
I hope to do a decent job with the build log itself as well and make it easy to follow and provide plenty of photos of the milestones, this part is also new to me so I may have to edit my posts a few times.
Lastly, as of now I don't have quite everything figured out yet or purchased (such as what specific power button I want to use and where to put it) so I may ask for some general thoughts on those things throughout the process.
Thanks for checking this out and I hope you enjoy!
**Edit: I welcome and thank the generosity of https://cablemod.com/
for sponsoring my build.**
The Components:
Top Drawer:
Bottom Drawer:
Base Cabinet:
Assembly:
Final Comments
