1 - 20 of 159 Posts
Images are always compressed to less than 100kb each and also resized to either 320x320 or 640x640, for your ease of viewing
http://img837.imageshack.us/i/img2966dy.jpg/
http://img585.imageshack.us/i/img2971u.jpg/
http://img502.imageshack.us/i/img2371r.jpg/
http://img4.imageshack.us/i/img2340dp.jpg/
http://img201.imageshack.us/i/img2331e.jpg/
http://img405.imageshack.us/i/img1866ju.jpg/
HEY GUYS!
This is my third case mod on Overclock.net and I figured out I would try something a lot different with cases.
And instead of MODIFYING a case, I decided to MAKE one.
After going through loads of Metal cutting Dremel discs and eating through sheets of case metal I have decided to do some wood-working.
YES Despite being a case made entirely of 7mm plywood, PVA strength glue and screws, this case will be holding WATERCOOLING COMPONENTS
This will be frequently updated during the school holidays, weekends and on school days I will only do planning and the odd gluing or minor jobs.
From this modification, I hope to gain experience with woodworking and more with the modding world, but ultimately I hope to end up with a sexy new case to stuff with overclocking hardware :)
As the name has already suggested, this will have separate compartments and the ideal structure of a computer will be exploded and reassembled into "Annexed".
With the plans all ready...
May the journey begin~
~List of Updates~
1
1.5
6
7
8
9
10
10.a
11
12
13
14
15
16
17
18
19
20
21
22
23
23.a
24
25
26
27
28
29
30
31
Programs used for images:
RIOT: Image Optimiser 3.0
Perfect for compressing an entire folder of images VERY QUICKLY! When I say quick I mean quick
Image Shack Uploader
General uploader program, upload all the pictures you want!
@knightsbr1dge
Sounds good
Can't see the images though, shows as a "403 Forbidden". Might want to look into that
Update 1
So, I kicked this modification off just today (and days before, but they were just collection of components
I had left-overs from my previous case mods, i.e the Darkc0d3r which I haven't finished and won't be finishing.
Stuff includes a Thermochill PA.120.3, assorted fans, nuts + bolts, I/O Panles, cables and lots more stuff.
I guess the best components I have are my Cougar Vortex 120mm fans, Thermochill PA. 120.3 radiator and my fan controller
Finally got the ISO right for this image; this shows the true sexy orange of Cougar Vortexes
Now it's time to get some actual work done.
Bought some Plywood from Bunnings Warehouse just yesterday (for all ya Aussie viewers)
A pretty beautiful piece of plywood I have to say, was the best out of the whole pile anyways.
No knots no nothing.
Also purchased a 2pack of brass plated Hinges which will serve as something I will explain later.
Time to get this beauty cut-up to my liking, wood and sketchup model on laptop all ready.
The "workstation" I have to work on at the moment, the shed is too full and hot for my liking.
Hack saw! I started feeling the difference now, back then all I did was flip out the Rotary Tool and slap on a Dremel Cutting disc. Only just starting to get used to the whole wood-working idea
BECAUSE I WAS TOO BUSY WITH CUTTING. I didn't take any pictures of the cutting process, so all I hvae to say at the moment is: "I need to start sanding the edges down"
Now here is when the trouble began.... all I had was sand paper and the highest grit garnet abrasive sheets took a truckload of time to get it down to THIS. (partly because of my horrible hack-sawing)
Resorted to using sanding barrels, they were a definite no no, stupid OZITO accessories were a waste of time and money.
Well I'm going to be going off to purchase some kind of sanding tool tommorow at Bunnings again, for the moment here is a little mock set-up of what the panels will be like when placed in their final set-up
2 Compartments, 1 for the main hardware and the other for cooling, power and harddrives.
Can't wait to paint these things : D
Well anyways I'll be posting an update early tommorow (because I've basically purchased the tool and it's right here).
I have already sanded the edges down for the panels and some other stuff so stay tuned for tommorow's update.!
Stay tuned for more!
Discussion Starter #4
Originally Posted by Sunny Sahota View Post
Sounds good
Fixed sir
And just after I threw up the first update.
It's probably because I cleared up my ImageShack space, I deleted the uploaded pictures along with the old ones haha
Discussion Starter #5
Update 1.5
Okay so I'm on early to fix up another update for this work log.
This is what I bought at Bunnings yesterday:
Opening up!
Spare gear or something like that.
Here's the belt sander; it was much larger than I thought it would be hahaha
Everything ready to go!
Practicing on some spare plywood... this thing chunks away a lot if you're not careful and even with your work
If you guys look closely below you can see the ridges where there is a depressison on the surface.
Clamped down on a ghetto bench vice
Quick clamps are SO handy now that I own them, they make life so much easier for modding and cutting.
And a bucket of rain water to use as a heavy weight.
What wood turns into when you sand it down; IT'S SNOWING : D
Time to fix up the edges. While I was using the Hacksaw the edges sometimes split (as the hacksaw really isn't a neat tool) so I have to putty them up and sand them down later.
I KNOW THAT IT'S CEDAR PUTTY and the colour of my plywood is cream, but I will be painting and lacquering the planks of wood so it'll be all good.
So that's all I did yesterday hahaha.... although it may have many pictures all I have done is sanded and puttied 3 panels of "Annexed"
There should be time today but the weather looks as if it won't hold up so I shall see if I have time to work on it today.
The top edge of the chair is now fully flat, I guess this would be great for a Ghetto benchvice afterall
Anyways, this concludes the second update of my worklog.
Feel free to put in a comment! Though I know how OCN works with case-mod worklogs :)
Discussion Starter #7
Update 2
Woot so I got a few stuff done last night, mainly sanding, finishing the HDD mounting and mock assembly of the panels.
The putty dried up well last night, and now it's fit for sanding.
Now with the panels done, I'll be moving on to the Harddrive Cage.
With CM Storm Scout users this may be familiar, why? Because this was extracted from my Scout case from my first mod
I have a stack of these HDD rails which attach onto the Harddrives like so, it'll be a waste of case if I don't integrate it into "Annexed"
They slide into the 'slots' in the HDD cage lie so:
Now, my aim is to secure or make a wooden base for the HDD cage so it can be stable.
First up is measuring.
My neighbor's drill and my belt sander, man if I didn't buy the belt sander everything would be so much harder right now.
I RECOMMEND THE BELT SANDER TO ALL WOODWORKERS, IT'S A MUST!!
See? Such straight finished cannot be accomplished without a proper sanding tool.
Now fitted on:
Mounting holes marked out (intersection of lines)
Since my neighbor doesn't have any drill bits small enough I'm going to have to use my own Ozito rusty drill bits.
But they still do the job well!
Top is bolted on.
Now just to tell you guys, the HDD cage will be lying HORIZONTALLY like so:
Reason being is the Thermochill PA.120.3 cannot fit if it is standing verytically, and also it looks cooler lying down : D
With the second attachment:
And to explained my arrangement, the HDD cage will be REMOVABLE in case I need to access the POWERSUPPLY which is mounted behind it. So what I have made is a 'sliding' mechanism where the HDD cage will slide along its wooden 'buffers' along a ceratin wooden bar which I will be making.
Everything will make sense soon guys!
Can you guys see the little piece of wood on the left? That is NOT going to be glued onto the HDD wooden plate and instead will be glued to the base of the case, the bolts you see on the right will slide into GROOVES I will make on the right panel.
Also, something cool I found out.
Mounting the belt sander on its back, it allows me to simply sand a piece of small wood (the buffers) easily, and the edges are super straight. And again, the belt sander is EPIC
That was last morning, now I'll get onto the REAL set-up so you guys can get a clearer idea.
All the stuff.
LOL! Penguin power
A gigabyte mATX board and an 8400GS for modelling.
It shall be mounted onto the 'column panel' which you guys will see later.
SO HERE IT IS:
THE COOLING COMPARTMENT:
HARDWARE COMPARTMENT:
Still having a think about the cooling of the Northbridge and southbridge.
So I hope that has given you guys a much cleaer idea on what this will be looking like.
And that's really it for now, I will be purchasing more Plywood panels for the BASE and the TOP PANEL sooner or later so stay tuned guys!
Please drop a comment and suggestions or just anything will be okay!
@knightsbr1dge
Coming along nicely!
Originally Posted by LokSupguller View Post
Locked indoors by the crappy weather : (
I guess there won't be an update for today
you got the terrible weather too did you?
it was raining at my place for like 8 hours straight today
The rain is meant to last for a few days past Australia Day tomorrow so I guess there wont be updates for a while
Discussion Starter #13
Originally Posted by Darr3n View Post
Can't wait to see the final project!
subbed!
Thanks for the support guys! I really appreciate it
Discussion Starter #14
Originally Posted by Ace_finland View Post
I'll take you rain and you can have my -21C and snow instead
Ahahaha, I'd actually prefer snow for a few weeks because I've only ever touched snow once in my life so far
But I'm pretty sure I'll get sick of it after a year.
Yea I know I saw the forecast... it's pounding so hard on my tin shed WHICH IS RIGHT NEAR MY WINDOW
I guess, I'll be working on:
  • Marking out motherboard holes
  • Marking out the Motherboard I/O panels
  • Graphics Card PCI slot holes.
  • SEARCHING FOR A JOB TO FUND THE MOD
So yeah for now I'll squat at home not doing much
Discussion Starter #15
Hey guys!
I just want to share something with you guys, especially for Scratch case modders out there.
There really isn't a "template" for the motherboard mounting holes which you can print out, as it is really too big to fit on a single A4 sheet of paper.
Instead you can use Sketchup to open up a basic template I found on Jezmckean:
http://scc.jezmckean.com/cat/20
One of the models there: "Blank Motherboard and PCIe Card Models" is excellent for measuring and referencing.
Use the measuring tool for this kind of stuff:
I found this was very useful (I'm marking out the motherboard mounting holes at the moment
) and I just wanted to share this with you guys.
Cheers
Discussion Starter #17
Originally Posted by Hydrored View Post
Check out page 12
atx2_1.pdf 275k .pdf file
I have already done that sir
The measurements there are in inches and I really do prefer centimeters and millimeters.
I also found that diagram a little difficult to use, the Sketchup model is 'hands-on' so you can get what you want quickly, but that was just my opinion
Check out page 12
Gotcha. I had it sitting on my desktop I figured it wouldn't hurt
positive rep for an epic build!
1 - 20 of 159 Posts
