screen wont turn on?!
601 8
first off just a quick background.
My computer before this one trashed video cards left and right.
so i basically rebuilt it.
new mobo new cpu new fans
now my computer worked fine for a few days and all the sudden my screen isnt getting any signal and its shutting off after a boot.
The video card im using is tied directly to the board.
my power unit and my HD are both from the unit before this one.
I have a new HD with SATA control What do I need to turn this thing on?
SATA controller? and SATA power cable?
does it sound like my power unit is doing the baking and should I replace it?
And last did I trash my MOBO or just the video Card on the MOBO?
1 - 9 of 9 Posts
sounds to me like theres a lot of baking going on....especially by ur mobo....try swapping the card to another mobo and see....btw, did u change the mobo?
WOW... that is a mess of stuff!
First of, what is teh 12V+ rating in "amperage" ... look on the PS sticker it may shoe something like 18a more or less!
When you have a bunch of problems that don't make sence I look at the PS first!
well the power supply is an older model.
Im going to switch out the power supply first to see if that makes a difference.
My biggest concern is getting this thing up and running than I can put on a new video card.
Id rather not spend 400 bucks on a video card just to have it fry.
the only problem im experiencing is the video card keeps poping
IM really worried I might have fried my MOBO
and yes my MOBO is brand new only about 3 weeks old.
Try resetting the bios using the jumper.
forgot to mention
the computer worked fine untill I installed the Big Typhoon cooling fan
Now its busted
I treid taking the fan off and using the old one
NO GO
anyone with similiar problems with this MOBO?
Originally Posted by 0d3n
forgot to mention
Now its busted
NO GO
You may have bumped into something during the install. Try clearing cmos and see what happens. Also re-check all connections inside. Make sure ide/sata cables are plugged all the way in. Re-seat all memory and cards.
Discussion Starter · #9 ·
MY F-ing PINS WERE BENT!
Jesus
when i took out the old cpu fan it must have messed up my pins
I spent three hours wit a freaking sodering tool and a magnifying glass straigtening pins to make the thing work again.
::SIGH::
ohh but it works
screen comes on no problemo
Now that that works i need to install the next of a few more mods.
Once everything is in new and happy places
the case modding begins
P.S. Thermaltake big typhoon is the largest fan ever made by the hands of man.
also arctic silver 5 gets EVERYWHERE!
a lil dab will do ya
1 - 9 of 9 Posts
