The Club
Under New Co-management!
Additional photos here
This thread is to be used as both the club for the Scythe Mugen 2 and as an information and question repository.
DARK KNIGHT vs MUGEN 2
MUGEN 2 WINS
FAQ
If you want to have information added, please PM me
Note: Please tag all Mugen 2 related PMs as [Mugen] in the title.
Overclock.net Reviews of the Mugen 2 can be found Here.
More Reviews:
XbitLabs
Tweaktown
Pro-Clockers
Tech-Reviews
Which cooler is better, the Xigmatek Dark Knight or the Scythe Mugen 2?
The Scythe Mugen 2 consistently receives better temperatures than the Dark Knight. The Mugen 2 also comes with mounting for the LGA 775, LGA 1366, LGA 478, AM2, AM2+, AM3, 940, 939 and 754. In addition, up to 4 fans can be attached opposed to only 2 on the Dark Knight. The included fan, a Scythe Slipstream, is considered to be quite silent aswell. The Scythe Mugen 2 also does not need to be lapped. The Scythe Mugen 2 can also be mounted up/down and left/right, while the Dark Knight only works up/down*, which may not be optimal if you have a top-mounted PSU or weak/no top fans. However, some drawbacks are that the Scythe Mugen 2 is not as easy to mount, and the Scythe Mugen 2 can block RAM slots if you have tall RAM heatsinks, such as OCZ reapers or Corsair Dominators. The Mugen 2 is priced $5 to $10 cheaper than the dark knight.
*on certain AMD sockets
How does it compare to a Thermalright Ultra Extreme (TRUE)?
The Scythe Mugen 2 can compete with an unlapped TRUE, however, when the TRUE is lapped, it will perform better than the Mugen 2. Since the Mugen 2 is already very flat, it will not see much performance gain when lapped, so a lapped Mugen 2 will still be out performed by a lapped TRUE.
How does it compare to a Megahalems/SuperMega?New!
Megahalems & Super Mega beat it, hands down. However, the Megahalems are more expensive.
Do I need to lap my Scythe Mugen 2?
No, you do not, since it already has a very, very flat base. However, you can if you want to.
What thermal paste comes with the Mugen 2?
Scythe-rebranded generic stuff. Its acceptable, but you are far better off using a different paste
What fan comes with the Mugen 2?
Scythe Slipstream 1200RPM
Isn't the Mugen 2 gigantic?
It is a large cooler, but unless you have very tall RAM, your Mugen 2 will NOT block any RAM slots. At worst, it will hover over your RAM, but still allow for 'normal' sized RAM sticks to fit under. In some cases, the fan may have to directly rest on a RAM stick.
How should I mount my Mugen 2
You should mount it so that the ridges go with the airflow. You also want to mount the fan on the longer broader sides. This typically means the Mugen 2 will be mounted Up/Down, as seen in this picture. The reason why is the ridges will create turbulence if the air flow goes against the ridges, and the ridges were created to move more air through.
What is the best thermal compound for the Mugen 2? New!
The usual good thermal compound works great with the Mugen 2. These include OCZ Freeze, Arctic Silver 5, Indigo Extreme, IC Diamond, and a few others. The stuff that comes with the Mugen 2 isn't very good at all. Both the Rice Grain and the Pea methods are successful and recommended around here.
What is the difference between the original Mugen 2 and the 'Rev B.' Mugen 2? New!
Although the heatsink itself is identical to the 'original', the Rev. B has a new mounting bracket, and adds compatibility with the LGA 1156 socket. You no longer need to change the backplate out either, as the new backplate goes around the installed backplate. Installation of the Mugen 2 Rev. B, however, is still a bit of a tricky effort.
The Rev. B box will have yellow/green highlights near the top of the box. The Original Mugen 2 will have blue/purple highlights near the top of the box.
What fans should I put on my Mugen 2?New!
Although the stock fan that comes with the Mugen 2 performs decently, you might want to have a look at this thread. Its for the Megahalems (Another very fine Air cooler), but it should give you a good idea of what works for the Mugen 2. Expect more information coming soon.
How should I mount my 2nd fanNew!
Scythe has fan clips available for purchase, however, you can find many home made solutions for mounting your Mugen 2.
Paperclip Mount
Paperclip Mount 2
Zipties
VERY BEAUTIFUL Zipties
Twistties
Mugen 2 Installation video:
Benchmarks and Temperatures:
_Marvin_
PowerTrip
If you have anymore information you would like in the FAQ, please PM me.
For membership inquiries, PM Powertrip (The Co-Owner, his post is underneath)
MUGEN 2 WINS
FAQ
More Reviews:
XbitLabs
Tweaktown
Pro-Clockers
Tech-Reviews
Paperclip Mount
Paperclip Mount 2
Zipties
Twistties
_Marvin_
PowerTrip
