Scythe Mugen 2 or Spire Fourier IV
380 Views 7 Replies 7 Participants Last post by  D3FiN3 SiN
Scythe Mugen 2 can get for 30€
Spire Fourier IV can get for 20€
i dont wanna spend alot of money cuz soon i am gettin a new rig (2months max)
i am testing my OC knowledge so i need a new fan cuz i use stock one
also which material is better for cooling copper or aluminium ???
1 - 8 of 8 Posts
Yes copper is almost twice as conductive as aluminum.
I don't even know what a Spire Fourier is...gonna have to look that one up...
EDIT: Just looked it up...terrible...go with the Mugen 2 if that is your only other choice. Xig Dark Knight is another great inexpensive choice and possible CM 212+ if you want something even cheaper that still does well.
P.S. just because it looks copper does not mean it cools better. The heat-pipes on a cooler cool better then the fins alone. The surface area of the fins are used to dissipate the heat from the heat-pipes but if there is not enough heat being transferred via the heat-pipes it makes the fin arrays pointless.
EDIT2: post 1666....scarwy!
Mugen 2 is far superior.
ROFL! The Spire on this review only cooled 3c better with max fan speed then the stock AMD cooler....pathetic.
LAWL!
Loooks like its for a HTPC.
Two very different coolers.
1 - 8 of 8 Posts
