1 - 3 of 3 Posts
I was wondering if it's possible to take off the backplate from the Scythe Ninja. I peeled off the paper it's stuck to my motherboard. I have this on my P5W-DH and I don't want to pry it in case it'll knock off leads and such on the bottom of the motherboard and I don't have much of a budget to replace it.
Can you post picks, I have a Ninja but I dont know what you are saying. Post a pic and I will try and help.
its very hard to take the backplate off after you have glued it......<br />
the 3M glue is pretty strong<br />
<br />
i killed a dfi ultra-d trying to remove the darn thing<br />
<br />
<a href="http://imageshack.us" target="_blank"><img src="http://img226.imageshack.us/img226/3430/dfirip004vd3.jpg" border="0" alt="" onload="NcodeImageResizer.createOn(this);" /></a><br />
<br />
<br />
try a heatgun or a blow-dryer and use lots of careful<br />
<br />
good luck on that
1 - 3 of 3 Posts
