Scythe Slip Stream question!!!
307 Views 6 Replies 4 Participants Last post by  Lukeatluke
Does anyone know if you get beside the fan one 3 pin adapter so you can connect them on the motherboard.
As i see here, is adapter useless because connector is the same like on the motherboard and not the right one as it should be.
1 - 7 of 7 Posts
The fan already uses a 3-pin, what you're looking at is a molex adaptor.
Oh, so it does come with molex so you can connect it on the power supply.Oh, that's ok then
Thanks, rep++
He's right ^. What you're looking at is an adapter to run it from your power supply instead of the motherboard or fan controller. I have three of these, they come with the three pin plug on them.
Edit: guess I'm a little slow to the keys
Heh, i thought they included 2 which i don't need.
The fan comes with 3pin(motherboard) and adapter for power supply, and was worried that i can only connect them to the PS so it's ok now
Originally Posted by Dotard
inclusive
(making about about exclusive language)
Correct
I need to learn English once for all.
sLOVEnia rulz
EDIT: I would say the same(wrong sentence), so i thought i had wrote that
1 - 7 of 7 Posts
