1 - 5 of 5 Posts
Overclock Failed...
Originally Posted by Slightly skewed View Post
So does anyone have any idea what their temp tolerance range is?
Much higher than anything you'll see in a computer case.
Why do you ask?
um, the the oil in the bearings will freeze, breaking them. Its not going to be before about -100 degrees F, which is highly unlikly, in a computer case. I would wory about condensation building up on fan blades before temp threshold.
1 - 5 of 5 Posts
