I have the following annotated class that I am trying to sort the results from a lucene/hibernate search query. I finally have the query working properly but it seems that when I implement the necessary annotations (seen on jobStatus) to sort that column, it makes it impossible to then search that column. I am basing this off the instructions I foundhere on google I have been having issues figuring this whole hibernate search and sort thing out, now that I finally figured out how to sort and search all I need is to be able to do them together, does anyone have any experience with this?
According to the hibernate book the first column should make a tokenized field that should be searchable, while the second should be untokenized and therefore fine for sorting, for some reason it can sort on it but just not search.... I've also tried switching the order of what field I declare where, using
and mixing and matching almost every combination of the parameters.
store = Store.YES
@Column(name="jobStatus", nullable=false)
@Fields({@Field, @Field(name = "jobStatus", analyze = Analyze.NO)})
private String status;
Field[] allFields = this.type.getDeclaredFields();
SortField field =new SortField(sortColumn, SortField.STRING, reverseSort);
Sort sort = new Sort(field);
hibQuery = fullTextSession.createFullTextQuery(bq, this.type).setSort(sort);
results = hibQuery.list();
