SeaSonic X-400 400W 80 Plus Gold Fanless ATX12V / EPS12V Power Supply
Description:
SpecificationsMfr Part Number: X-400/SS-400FLFeatures: 80PLUS Gold Certified Super High EfficiencySeasonic DC Connector Module with Integrated Voltage Regulator ModuleDC to DC Converter DesignConductive Polymer Aluminum Solid Electrolytic CapacitorsHighly Reliable 105°C Grade A CapacitorsTight Voltage Regulation (±3%)Active Power Factor Correction (99% PF Typical)High +12V OutputHigh Current Gold Plated TerminalsDual Sided PCB LayoutUltra Ventilation (Honeycomb Structure)Full Modular Cabling DesignAll-in-One DC Cabling DesignEasy Swap ConnectorUniversal AC Input (Full Range)Total Power: 400 WPower Factor Correction: Active PFC, 99% typicalSafety: CB, cTUVus, CCC, TUV, GOST-R, BSMI, CE, UKR, FCC, C-tickPower Rating: +3.3V @ 20A; +5V @ 20A; +12V @ 33A, -12V @ 0.5A, +5Vsb @ 2.5AInput Voltage: Full Range - 100 ~ 240V (Max. 90 ~ 264V)Input Frequency Range: 50 - 60 HzInput Current: 6 - 3AMTBF: >100,000 HoursConnectors: 1x 20+4 pin Main power; 1x 4+4 pin CPU Power Connector; 1x 6+2 pin PCI-Express Connector; 5x 4pin Peripheral Connectors; 5x SATA Connectors; 2x 4-pin FDD ConnectorsDimensions : 150.0 x 160.0 x 86.0 mm/ 5.9 x 6.3 x 3.4 inchROHS Compliant
Details:
Description:
Details:
Detail | Value |
Binding | Personal Computers |
Brand | Sea Sonic |
Label | SEASONIC |
Manufacturer | SEASONIC |
MPN | X-400;SS-400FL |
Publisher | SEASONIC |
SKU | PS-SS400FL |
Studio | SEASONIC |
Title | SeaSonic X-400 400W 80 Plus Gold Fanless ATX12V / EPS12V Power Supply |
PackageQuantity | 1 |
PartNumber | X-400;SS-400FL |
ProductGroup | PC Accessory |
ProductTypeName | SYSTEM_POWER_DEVICE |
Item Weight | 8 pounds |
