1 - 11 of 11 Posts
<a href="http://accessories.us.dell.com/sna/productdetail.aspx?c=us&l=en&s=dhs&cs=19&sku=A0199027" target="_blank">http://accessories.us.dell.com/sna/p...9&sku=A0199027</a><br />
<br />
I am using that wall mount to secure my prospective E207WFP, and I need a security solution to keep it from being stolen- Does anyone have any suggestions?
gorilla glue?
A really big chain, with a small padlock
is your house robbed that often?
Discussion Starter #6
Not that it is robbed often, because it isn't <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
I was thinking with the possible amounts of traffic a dorm room might have, the opportunity for such a thing might be greater.
Automatic heat-seeking turrets.<br />
<br />
<br />
Or a security camera, which would probably be a much simpler solution.
You could use tamper proof torx screws, or you could use the kind of screws(don't know the name) you see in the bathroom stalls at you school. You'll never make it unstealable,you just need to make it harder. The old saying "lock only keep honest people out"
Reactions: Burn
I'd do like was already suggested. Special screws. They have a sort of wave-pattern so you can only tighten them. It's a real pain to loosen them. That coupled with keeping your door locked should be adequate. Xbox, LCD, computer, and $700 surround system was just fine it my room and none of it was secured. Just kept the doors locked when I wasn't around.<br><br>
If you really need something better, a Tesla coil would be my next choice.
<div>Originally Posted by <strong>C-bro</strong></div>
<div style="font-style:italic;">If you really need something better, a Tesla coil would be my next choice.</div>
</td>
</tr></table></div>
<br>
That's freakin old school right there...<br><br>
I live in a dorm too just don't tell a whole bunch of people about it and keep the doors locked!<img alt="" class="inlineimg" src="/images/smilies/thumb.gif" style="border:0px solid;" title="Thumb">
Discussion Starter #11
<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /> Thanks a bunch.<br />
<br />
I think I will go with the special screws- That seems to be the best course of action. Thanks again guys <img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
1 - 11 of 11 Posts
