teh tube will be a somewhat reservoir where the air will go cuz i dont have room for actual reservoir and it will be sealed at the end. rad is honda accord heater rad (year 97-98 something something). Tube will not stick out like that.Originally Posted by GaMbi2004
im a bit confused.. im sure the two loose ends will be connected to a CPU block.. but what about the inlet? are you gonna have a tube sticking out like that? or is the T piece being switched with a reservoir?
what radiator is that?
but yea.. it looks like it could work!
Pump is a Bosch PA66-GF30 Mercedes-Benz water/coolant circulation pump and cpu block is custom made by me (cant show pics cuz they are in that same pc on the picture that aint working atm). I would create a build log for this cooling loop but i am not sure that i could manage this.
