1 - 20 of 85 Posts
Bear with me as this project will span some time.
So I've been playing around with servers in my free time(which isn't much) and finally decided it's high time to get my house wired up properly. It's also helpful now that I actually own a house that I can modify to my liking.
So here's the current mockup of what I'm heading towards.
On the left side, the two 2x4s are spaced just over 21" apart, this is close to what I need but just a bit too much. I'm going to have to install a spacer to reach the proper 19" width of my rack. On the right side is just enough space between the studs to install slide out shelves to hold up to 2 ATX tower cases. Until I start acquiring actual server boxes, this will be my server platform.
The Plan:
- Wire the house with CAT 6 cable to enable connectivity growth for present and future applications.
- Build stationary rack and tower case shelves using existing framework of staircase to basement.
- Purchase a quad or dual NIC to finish PFSense build and get it configured/installed.
- Purchase patch panel and switch to fit in new rack.
- Set Wireless router to AP mode, check old router for same functionality.
- Move file/backup server to sliding shelf.
- Move PFSense build to second sliding shelf
- Run coax cable from cable box to modem in basement
- Purchase remaining Node Zero equipment.
- Install NZ equipment.
- Install XMBC on old laptop to co locate with living room TV as server/media center.
Materials:
Have
- File/Backup server in Full Tower ATX case
- PFSense build(minus NIC) in mATX eMachines case
- Sliding Shelves Hardware and wood for shelves
- Netgear AC Wireless Router
- TP-LINK 5 port switch
- Netgear Wireless Extender
- Old ASUS laptop to use as media server
- Surge protection power strip
Need(list will continue to grow as planning continues)
- 16+ port gigabit switch
- Rack rails
- 2x4s to finish rack structure
- 4+ device KVM(USB)
- Slide out rack tray: Keyboard/mouse
- 1000' CAT 6 solid copper cable
- CAT 6 wall plates and jacks
- CAT 6 patch cables .5 to 3 feet length
- 16+ port patch panel
- UPS Power Distribution
Well, that's all the time I have right now. Stay tuned for updates as I get this planned out more detailed.
Overclock Failed...
Bench grinder = metalic dust = shorted components.
Sawdust = clogged case fans = overheat.
Looks like this is a workshop area. Perhaps enclosing the stairwell and filtered intake fans?
Discussion Starter #4
Yeah, the plan is to filter that well. It is a workshop area, but that bench will get moved sooner than later. I came home to find my father in law set that up there. Which is crazy considering my work area is on the other side of the 1400 sqft basement
But the plan is to enclose that area with filtered intakes and cabinet style doors on the front and rear. I just didn't add that to the Sketchup for time reasons. I will be revisiting the enclosure idea right before I start altering the framework.
Originally Posted by DogeTactical View Post
Love the idea!
Billbartuska makes a good point though
Thank you! Surprisingly enough it was easy to convince the wife to let me have that spot. I guess the "When we finish the basement it'll work perfectly and stay out of sight" was enough.
Overclock Failed...
When you get ready to build a workshop, "And over here, far away from the workshop, will be your crafts area." works well.
Discussion Starter #7
Funny you should mention a craft space. For her mother's day gift, she is taking over the bay window sitting area and turning it into her craft space. The gift is to build her a craft desk. Sketchup below of the simple yet functional design.
Have you figured out I like Sketchup yet? haha
Sketchup is perfect for getting ideas into a 3d space quickly and easily (and for free)
Seem like a neat project you have going on! Will be following
Discussion Starter #10
I fell in love with Sketchup when working out my design for my Double Dragon build. Being able to see something in 3D space really helps you understand how things need to fit and if there's adjustments to be made to make something look cleaner.
So my friends over at OCF brought up the point of airflow once it's been shut in. I responded with the following proposal: to put intake filtered fans in the stair risers starting at the 3rd step from the bottom, exhaust grill will be placed at the back and top of the stair area. Adjustments to Sketchup for visual below.
Overclock Failed...
Exhaust high, intake low.
Moderator
Looking like an interesting build for sure
Moderator
I would worry about those intake fans on the stairs, since the stairs will likely collect a good amount of dust, those intake's filters will get clogged up pretty regularly, you could probably just do a giant furnace filter like thing to the left of your rack and either duct it to the lower part of that area so the natural convection can still take place, and as long a the exhaust fans are on, it will suck some air in through the large intake hole.
Also you might want to look in to all the hardware you are using in the rack as many rack mounted devices actually intake air through the front and spit the hot air out the back. So what you can to is actually recess the entire rack 4-5" in to the wall that way you have some fresh airflow up the front of the rack for all the hardware when the cabinet is closed.
You can design the entire front area to be somewhat sealed off aside from a hole in the bottom and put 2 fans down their to force cold air form the floor up the front of the rack. then all their exhaust air will go out the back and rise up to the exhaust fans near the top of your wall cabinet.
I could make some quick sketches if I'm not coming across clearly, I'm use to just drafting in 3D my ideas at work as I'm not the best at explaining things.
Discussion Starter #18
Post 5/11/16 - The server builds
File/Backup/Minecraft Server Build
After two back to back upgrades for my main rig, Night Shark, I was left with both an AMD ATX DDR3 setup and an AMD mATX DD2 setup at my disposal. Of course running minecraft servers for friends, and having better performance I naturally chose the DDR3 setup with the quad core Phenom.
Specs:
CPU: Phenom II X4 945 3.0Ghz
Motherboard: Asus M5A88-V EVO
RAM: ADATA 6GB
Hard Drive: WD Black 1TB & WD WD3200 & WD WD800(OS) & Hitachi Deskstar 160GB
GPU: None
Power: Raidmax RX 530W
Cooling: Xigmatek Loki
Case: XCLIO A380BK
OS: Ubuntu Server
Old Hardware before…
Upgraded
It works!
PFSense build:
So I finally managed to get ahold of a trash-borne ATX case. A local gentleman had some cases that were headed to the scrap yard. Ended up getting a e-machines mATX, and two slim ITX cases for free. I also bought a 1TB WD Black off him for $10 and he threw in an extra 60GB drive.
Parts acquired:
Time to begin:
Cable management = meh:
First power on, everything works. I was worried that only running a PSU with a 20pin ATX power and a 4pin CPU would hold the build back. Didn't want to use the bulky non-modular 580w that I had because the cables would've been a rats nest. PFSense is installed and I had a chance to play around with it hooked up to my network. Once I went through the initial setup(cakewalk) immediately I had internet access and full configurability. Took the time that my wife was out on a "Mom's Night" to familiarize myself with the menus and settings while the baby played. Looking forward to getting this set up in Node Zero with the proper cables ran.
Specs:
Mobo: GIGABYTE GA-MA785GM-US2H
CPU: Athlon II X2 220 Dual Core 2.8Ghz w/ stock cooler
PSU: I forget, just old and low power.. and quiet
HDD: 60 GB WD Caviar WD600 IDE
NIC: Netgear 10/100 PCI card(until I purchase an Intel Pro Dual/Quad)
Discussion Starter #19
I think I'm following and that might work a little better. I'm always open to suggestions from design experts so I'm going to post my Sketchup file(once the upload error is fixed). There is a discrepancy with the stairs though. If anyone has the contracting experience to fix them, that would be helpful
See below for the discrepancy.
Curious to see how this turns out. With your stairs I personally hate having the turn like that because one side of the stairs are to small to easily step on, plus it takes thought when you carry something down the stairs and you can't see the steps. Axipher I think has a good idea for the vents. In your picture above the intake vents would go below "stairs follow a straight..." and the exhaust would go to the left of "turn towards...".
1 - 20 of 85 Posts
