1 - 10 of 10 Posts
okay i need help deciding between a couple cpu's
i am building a server build for super advanced editing and rendering of super high quaility video and i most likely will be doing extreme gaming so keep that in mind
I need to know if
the Intel Xeon W3520 Bloomfield 2.66GHz
or the Intel Xeon E5520 Nehalem 2.26GHz
or the Intel Xeon W3550 Bloomfield 3.06GHz
will be most optimal for my build i will have two of whatever processor on the evga sr2 mobo both water cooled with four gtx 580's; now my question is in your opinon which would be the best for my build or if there are any other server processors out there that are better and for around 300-400$ each.
(if you own any of these please tell me any pros or cons according to you experience)
thanks
well i am not actually using it as a server but; like i said i do advanced editing that requires a high end system
Originally Posted by allikat
Advanced rendering? Get a single Xeon, and pack it with GTX580s or Quaddros and use the GPU power instead.
I agree, rendering with GPUs is usually much more efficient. However, you should not get Quaddros if you plan on any gaming.
Personally, I think you should get an i7 2600k or (preferably) wait until Ivy Bridge is released along with the NEW enthusiast/extreme CPUs. I think Xeons are overpriced, and that you should opt for a single CPU setup.
Okay thanks for the suggestions, i was thinking the dual cpu is overkill so i will most likely wait till Intel releases its new ivy bridge
How often are you gonna do extreme gaming?
+1
Don't get the quaddros if you're gonna play games.
Discussion Starter · #9 ·
probably around once a day if my school doesnt go to intense but during summer a whole lot
1 - 10 of 10 Posts
