Hi there,
I'm currently setting up a domain in my house with the server listed in my sig. I'm on windows server 2008 R2. Right now, I have a switch connected to my router (my router is a router AND a modem at the same time). On the switch, my server and my other computers are connected, and some are on the router.
For now, my server does the DNS and DHCP part of my network, but the firewall and NAT is done by the router. The problem I have, is whenever I join one of my computers to the domain of my server, I need to point that server as the default gateway, therefore they no longer have access to the internet. Despite that, everything else work, I can connect myself on a user created on the server.
So here's my questions;
1.Do I need to desactivate the router part of my router so it only provide an internet access? I have a spare ethernet card that I can put in my server so I was wondering if I should plug the server in the router and then the switch in my server and use the server as a gateway point and as a firewall/dns/dhcp/NAT provider instead of the router.
2.I have 2 1TB drives in raid 1 in my server, if I want to manage who in my network as access to which folder, do I need a domain for that?
3. What antivirus should I use for my server and what firewall should I use on my server to protect my network.
Thank you very much for reading! If you have any question on my problem, ask me !
