1 - 1 of 1 Posts
Hi
I dont know if this is in the right place but here goes...
Ive downloaded this software called Serviio and its job is to be a DNLA Media Server. So anyway I added movies and music to its libary but it does not detect my XBOX 360
(under "RENDERER PROFILE" in the "STATUS" tab).
Here are some stuff you might need to know:
XBOX 360 is connected to router WIRELESSLY
PC is connect to router WIRELESSLY (but i did try it with a network cable)
if there is anything else you need to know just ask
Thanks in Advanced
1 - 1 of 1 Posts
