1 - 13 of 13 Posts
the mobo has no overclocking options and i was hoping to bump it up to maybe around 2.6-2.8ghz.
What are some problems i will have and how high should the temps go under load?
Discussion Starter #4
Originally Posted by chuckmcnugget
How will you overclock if it doesn't have the ability to
setfsb is software that allows you to bump up the fsb
What computer is it? If anything can do it then setfsb can. Just go to their website and Ctrl+F to see if they have the motherboard or PC supported.
The only way to know is to try it. Some problems (obviously) is the additional voltage needed to O/C and additional heat to deal with. Oh, and you have to know the clockgen for setfsb to work correctly.
Discussion Starter #9
whats the clockgen? I have never overclocked any CPUs apart from i7s
The PLL(Clock Generator) chip is on your MB, and allows you some control of the FSB and PCI/PCI-E buses in windows.
The information that SetFSB needs is as follows.
a. the motherboard(/PC) name
b. the chipset name
c. the clock generator name (PLL)
Mega put together a quick list of Setfsb supported PLL's HERE.
Discussion Starter #12
b. the chipset name
Well heres the mobo
http://www.ecsusa.com/ECSWebSite/Pro...uID=52&LanID=9
now where would i go about finding all the other stuff?
I don't see direct support for that MB. You may need to locate the PLL chip on the MB. Here's a guide that may help. Link
1 - 13 of 13 Posts
