Hello forum !
So I've got a network setup as follows .
The end goal is to set up a LAN with my Meraki Z1 that is bridged to the home hub either directly or via a bridge.
Basically I'm downstairs , I can access the config of both the firewall and the home hub no problem .
The home hub has no ports free so I can't use power-line adapters and Need to get a cabled lan out of it .
I have somewhere and old net gear router I could use to set up as a bridge ( potentially) unless anyone can come up with a better solution ?
Currently most stuff is connected via wireless which is fine but not practical for some stuff as mirror share is not possible over wireless for the TV.
The meraki Z1 from what I can tell does not do Wireless bridging .
Wireless signal is great so no worries there .
Whats the best solution ?
