setpriority question
279 Views 7 Replies 5 Participants Last post by  GeforceGTS
what is the difference between realtime and high priority presets? I know realtime uses a lot more threads than high, so is there any reason I wouldn't want to just use that on my folding cores?
1 - 8 of 8 Posts
seems like i've crashed a time or 2 while running realtime. High, not yet *fingers crossed*
i net about 200 more points daily roughly depending on the WU for my daily output changing my priority from low to high.
Other than that i can tell you nothing! :0)
haha our stats are both so close to eachothers
And by the way grats on passing me the other day
jerk
jerk
Thanks, I'll put it on realtime and see how things go. Rep+
Same here, I have no idea other than I get better PPD with realtime. I have never once crashed because of running realtime though and I don't get any slowdowns running other programs, I can still watch movies etc too without any problems, just kills my PPD a bit ;l
EDIT: You will soon be passing me too, my GPU is now folding under another name for the GPU comp
I realy need another 260...
I am confused as to what setting you guys are talking about.
In task manager under processes of you right click on a process you get the option to set a specific process's priotrity anywhere from low to realtime. At least that what I'm gettin out of it...
I tried setting them to realtime, my computer got so laggy I had to restart. Mouse lagged so much it would be trying to catch up and still moving 2 minutes later, stuff I clicked MIGHT recognize being clicked 3 minutes later. (actual times this)
Ouch, I know what you mean, I set my Vmware clients to realtime once and I couldn't do anything, I ended up hitting the restart button
Never had that problem with only the GPU though ;l
1 - 8 of 8 Posts
