1 - 5 of 5 Posts
ok so I just plugged everything in up and filled it for leaktests
I was just wondering which hole to put the intake in on my waterblock
the one with a block on the end or the one with nothing on the end?
help is appreciated
help is appreciated
What water block are you using? If its the TDX you need the 'IN' to have the little jagged block below it to spread out the water when it is pumpted into the block.
great thats what I have it in
do you guys run your setups 24/7?
I do. I was really worried at first. But it runs flawlessly, so i keep it on 24/7
1 - 5 of 5 Posts
