setting 8800gt as my PHYSX card need help
970 Views 21 Replies 13 Participants Last post by  skunksmash
hi guys i need some help from you guys
actually i have a spare 8800gt and i didnt knew what to do so my friends told me to use 8800gt as my PHYSX card
now i really dont know how to setup a card like that
can someone tell me how can i use it?
i mean is it like easy or it takes lots of time to setup
any advice would be really appriciated
thnxs for help
1 - 20 of 22 Posts
Its really easy, all you have to do is insert it into the next pcie slot and enable physx on the 8800gt in the nvidia control panel.
That.
Or why not sell it and buy a 2x2gb Ram kit and a Sound card.
I think that More ram will give you better performance than a physx 8800gt as not many games use it.
yah i have bought a 2gb x 2 kingston 800mhz ram just 4 hrs ago and iam using it
now guys i have inserted the card in the second pci slot and it is running but i dont think it recognises it
no option for sli/PHYSX for me even after the card is running
also i wanna lower the fan speed for it and it doesnt show me in evga precision also
any help plz iam gonna sleep in 5 min
EDIT does not show in system device also
Did you plug in the 6-pin PCI-Express power connector to the 8800?
Did you install the latest drivers that include the physx driver?
i have the latest drivers i think for the PHYSX coz i can go to that panel to turn it on/off
as for 8800gt yes i did plug in the 6 pin to it and thats y it was working
now i can hear the fan noise and it was like the fan was on 100% and 2 loud so i just took it off
the card does not even show in system hardware and when i put the cd for installing the drivers it says it cant find the xfx hardware for the drivers(my 8800gt is xfx alpha dog edition)
any help?
100% fan speed probably means you don't have the latest drivers.
Install Driver Sweeper.
Uninstall both Nvida and PhysX drivers.
Reboot into Safe Mode.
Run Driver Sweeper and a registry cleaner if you have one.
Reboot.
Install latest Nvidia drivers (PhysX are included).
Should work after that.
but i have the drivers installed for gtx 260 and they work great
which driver i should uninstall?
The complete nVidia display driver package. Then re-install the latest version, it's basically 1-in-all. You don't need multiple drivers for the videocards.
can u link me to the nvidia site where these drivers are?
coz the sparkle website does not work with driver download
Here you go http://www.nvidia.com/object/winxp_182.08_whql.html, it should install the latest PhysX software for you automatically, then go to the PhysX control panel and select 8800GT as your PhysX PPU.
thnxs dude
ok which drivers to install?
ok guys i have installed the latest drivers and still i cannot get that thing to work
here it is i fix the 8800gt in the mobo and then put the 6 pin in it
it is working as i can hear the voice of its fan
then i restart computer and then go to the physx option but i dont see the option of sli and such
is there something iam doing wrong? or something i shld do that i didnt
As far as I know, when you want this to run as physx you don't use the SLI bridge and therefore you can't sli 2 cards with different GPUs. if you mobo is sli capable and you do have 2 GPU that are similar, you must enable SLI in BIOS and then in nVidia control panel.
Just download the latest nvidia drivers(after you download driversweeper and run it 3 times) then right-click on the desktop and there should be the "nvidia control panel" option, click it. Now when the window pops up, there should be a tab on the left that says "set sli and physx configuration" under the 3d settings, click on it. There should be settings to turn on/off sli and physx. i hope that helped you.
guys i can hear the card working but i think the system is not catching it
it doesnt show in the system hardware and i only see my gtx 260
also i just took the card and applied it to the mobo and didnt do anything
if there is a special way please tell me like taking out something of the card or anything
1 - 20 of 22 Posts
