Hi, I was looking how to permanently set process affinity, and have finally found a way and i'm glad to point out that it works, even on Vista! I am using it myself for gaming.
Method
Download imagecfg.exe from here
on this site, there is enough instruction for you to follow, but for the lazy people, i will repeat this.
1. Download imagecfg.exe
2. Move it to %systemroot%\\system32 (example C:\\Windows\\system32)
3. Run CMD and type the following (example imagecfg -a 0x1 c:\\path\o\\file.exe)
4. Use the following commands to set the executable to your desired core/s
imagecfg -a 0x1 for CPU core 0
imagecfg -a 0x2 for CPU core 1
imagecfg -a 0x3 to reset to both cores
I hope this will help to solve problems
Method
