1 - 8 of 8 Posts
Originally Posted by KEITHRH12
How do you access ur bios for ur gfx card? rivatuner? F11 or something?
working on oc'd my 6600 256.
You need to backup your bios with nvflash and then edit it with nibitor in windows. Then use nvflash to flash it back again, if you make any changes. No 'on the fly' changes like for the motherboard.
nvflash? nibitor in windows?
like changeing apg aperature size, overvoltage, andagp freq? u can do that with rivatuner?
You'd need to go into your motherboard's bios to change these settings.
You can't change the voltage of the GFX though through here. You'd need to do a physical voltage mod on the card to do that.
You can use nvflash and nibitor to alter the bios of your GFX like its clock speeds, once you have found how far it can be overclocked.
bios is that f2 or f11, and can u can apature size in riva?
It depends on your motherboard, check your manual for how to get into the bios. No, don't think you can change any of these settings through Rivatuner.
You can change the GPU voltage, modding the bios with nibitor.
1 - 8 of 8 Posts
