1 - 13 of 13 Posts
With all the newer power supplies coming out in the market and many older units still going strong, I wanted to get some advise on some power supplies I have been looking at.
I know there is still a small market on SFF units which produce a decent amount of power but I have been looking at quite a few so far.
Here is a list of requirements needed & parts I have in my current build:
  1. Located in US.
  2. As far as Budget goes, honestly I have none but if I had to put a price, no more than $200.
  3. Looking for something along the lines of 500w < +
  4. Cables I prefer Fully Modular.
  5. Require 2 PCIe cables ( 8-pin ).
  6. Flat or normal cables, either/or.
  7. Build Specs
    • i5-4670K
    • MSI GeForce GTX980 - 4GD5T OC ( Armor 2X Black & White )
    • Two 2.5 drives ( one is a Hybrid drive )
    • 6 fans
    • Gigabyte H97N-WiFi Mini-ITX
    • Corsair Hydro Series H50
    • Corsair Vengeance Pro 16gb total
    • Case is a Thermaltake Core V1
These are the two in question so far:
Silverstone SX600-G
Corsair SF600 Gold
I need the PSU to be less that 180mm in depth which also led me to look at the Strider Series from Silverstone as well. I hope I am not asking a lot so please let me know what you all recommend or are currently using with good/great results thus far.
  1. Located in US.
  7. Build Specs
    • i5-4670K
    • 6 fans
Silverstone SX600-G
Corsair SF600 Gold
Corsair would be my suggestion. Based on reviews the Corsair did better, it's 80+ Gold certified. But I just realised that you are doing a V1 Mini build. They take ATX power supply's? So with that being said mine is a full ATX PSU. And I fit a ****load of stuff in that little box. Why go with SFX type PSU's? Preference? Concern for space?
One of the main reasons is space and cable management as I have a plan for the extra chamber below the GPU. I added a 40mm fan at the rear for a cooling mod I have in mind. I currently have a TPG-600M and although it works good, I had bought it used and fear it may be seeing it's maker soon LOL. I could certainly make due with a 140 mm - 160mm in depth power supply.
Could you consider part modular as the mobo connection are always needed and you could save some cash.
Senior OCN Member
The older Semi modular Cooler Master V is a good option.
Just dont get the newer fully modular version.
Senior OCN Member
Thank you, I will look into that one.
Its 140mm long by the way.
Ah, got it... so what shilka said to accommodate your needs in the build.
Discussion Starter #11
+1 TY.
@shilka I am curious....., would you choose the Cooler Master V over the Corsair SF unit? Was the price the factor in the recommendation?
The Cooler Master would more than do for sure. Everywhere I went and entered my specs for a PSU recommendation they all gave me ranges between 380 - 400 watts give or take and would recommend a 500-550 watt PSU.
Thank you all so far for the recommendations. I have not jumped on purchasing a unit yet but I will very soon as I want to finish this build once and for all. I have a VERY much older style mini case that I want to customize completely ( which I have already begun the process ) so I am thinking of purchasing two PSU's. At the most, longevity is one thing I want out of the PSU's so don't be afraid to suggest higher quality units. In the meantime I am reading up on reviews from here and other sites on the suggested PSU's.
Senior OCN Member
The Corsair is a little bit better but i think the Cooler Master might be cheaper.
1 - 13 of 13 Posts
