Hi All, I'm trying to complete my first pc build and have run into a somewhat vexing problem. I'm building inside an SG05B USB3.0 case with a ASrock z77e-itx MoBo. I've gotten so far as to try to connect the PSU to the board. There are two power connectors on the board, a 8-pin (ATX12v1) connector and a 24-pin ATXPWR1. The trouble is that the SG05's psu does not seem to have matching connectors. It has a 4-pin ATX12v connector and not an 8-pin. AND although it has a 24-pin connector, the pattern of square to curved pieces seems to be reversed, so that it will not fit into the MoBo connector.
Did I somehow buy the wrong mis-matching pieces? I would have thought this was standardized? Any ideas? I could really use any input!!
