Same as the original isn't it?
Minimum System Requirements Processor: 1.8GHz Intel Core 2 Duo or equivalent AMD CPU Memory: 1 GB RAM for Windows XP / 2 GB RAM for Windows Vista and Windows 7 Video Card: 256 MB (with Pixel Shader 3.0 support). Supported Chipsets: NVIDIA GeForce 6800 or greater; ATI Radeon X1600 Pro or greater. Please note that NVIDIA GeForce 7300, 8100, 8200, 8300, 8400, and 9300; ATI Radeon HD3200, and HD4350 are below minimum system requirements. Updates to your video and sound card drivers may be required. Intel and S3 video cards are not officially supported in Mass Effect 2. Hard Drive: 15 GB OS: Windows XP SP3 / Windows Vista SP1 / Windows 7 DVD ROM: 1x Speed Sound Card: DirectX 9.0c compatible DirectX: DirectX 9.0c August 2008 (included) Input: Keyboard / Mouse |
"a basic disk check" without online authentication |
Originally Posted by MrDeodorant ![]() Well, if you can get 8+ on a standard DVD, and the XBox can read HD-DVDs, I think they have the space. |
