1 - 5 of 5 Posts
Attachment 173376
as you see in this picture, there is 1791 MB shared system memory and total is 2303 MB..now i want to know cause i googled and didn't find anything, does this memory is realy used in games? because when i play GTA 4 when i enter in option menu under graphic it snows just 498 MB..and when i enter in task manager it snows that i have 4 GB of RAM..anyone tell me something about this?
When you have a dedicated card, like the 4770, you want to disable ALL forms of onboard video. Just to be sure that there is no issues. In-game it is going to use the card, hopefully, as you can have 10gb of onboard video memory and it wouldn't help an ounce in game performance.
then, shared system memory doesn't provide any better performance? so for what is then?
and how to disable all forms of onboard video?
512m = what's on the card.
4 GB = system RAM.
GTA IV reports dedicated video RAM.
Not really sure why you're worried.
You never want to use shared video memory, as it's much slower than dedicated.
Some new cards have over 100 GB/sec video bandwidth, DDR2 800 Mhz bandwidth is only 6.4 GB/channel theoretical max (12.8 in dual channel config).
Shared memory is just a marketing ploy.
"Look, this card can allocate 2.5 GB of memory so obviously it must be superior to a puny 1 GB card.."
1 - 5 of 5 Posts
