General idea was to use fairly low TDP components. I knew the motherboard would run very cool from prior experience. The ram is very efficient/stable as well. The GPU could definitely be more efficient, but the gpu craze was still in full swing (at the time), and the 1080ti does still perform well enough for me.
Specs are as follows:
Revolt 3 case with optional IBP 700W gold psu, Gigabyte b550i pro ax, 5600X, reference (low profile) 1080ti with slim EK waterblock, 2x16gb trident z royal cl14 3600, 970 evo plus 2tb
Cooling consists of a Bykski 280mm copper rad paired with a barrow 240mm copper rad. The 240mm rad is on custom brackets made from aircraft sheet aluminum, nothing fancy. It sits in front of the GPU where there is not supposed to be a radiator in this case. It's paired with 2 Arctic P12 slim fans. The 280mm radiator sits on the mounts provided for what most anyone would attach an AIO to. Using two Arctic P14 fans here. All four radiator fans running push/exhaust. They are all conveniently and neatly daisychained to eachother, and using one fan header. I didn't have to use any adaptors or anything. These fans have a great sound profile as well, and create good pressure to boot.
There is no reservoir in this loop, and no room anywhere for a pump either.... unless....
The waterpump is integrated into the Cpu waterblock. Now, be warned.... This integrated pump/block combo is designed very poorly. Theres nothing wrong with the pump, or the block... But the way it is arranged causes it to trap air, and it's almost... if not actually impossible to get all of the air out of it unless you use another pump in series.
I have it working now.... But it was seriously painful. Basicially I spent close to 10 hours initially trying to work all of the air out of this thing, following the factory instructions, ect. No dice. Eventually I managed to get some water behind my GPU waterblock and it fried. $200 and a month later, got my 1080ti working again. I hooked up another waterpump outside of the case with a reservoir to get the air out, and it was still a pain. But I got it done, and removed the extra pump. Put a T fitting in it's place.
At any rate... It runs Forza pretty well. (stable over 90fps in cockpit with these settings).
Here is also some temps afer runing Forza for a good 20 minutes. Keep in mind this board is passive cooled.
I'm sure in the future I'll need to upgrade the GPU, but I've already got a rx6800/6900 waterblock that will fit in here.
