1 - 2 of 2 Posts
Hi
Looking for an attractive heatsink solution for northbridge and VRM which fits my build - which is chrome and black.
Though obviously copper is beautiful as well as shiny, it doesn't fit the theme. I could possibly polish aluminium to a pretty high shine, though getting between fins would be very difficult.
I don't know if fully nickel-plated aluminium heatsinks are available, I haven't bean able to find any.
Any ideas or suggestions?
Thanks
9 Cans of Ravioli
For ... what board? They're not universal. And northbridges haven't been a thing in quite a while.
Chances are there aren't any. Waterblock/monoblock maybe, but not a replacement heatsinks.
Just paint the ones that's on your board now. If there are none, then chances are the VRMs aren't up to spec anyway and you should probably not use that board if you're planning on OCing.
1 - 2 of 2 Posts
