Set it up in the RAID BIOS. As for performance, you will only see lower seek times on the first partition (if it's less then 250GB), not the second. The read / write speeds will be slightly higher on the first partition as it closer to the fastest edge of the hd and will be consistent. The 2nd partition will still be quick, but will start to drop off as it reaches the other end of the hd.
