121 - 125 of 125 Posts
Originally Posted by djsi38t View Post
I did this with a caviar black laptop hd in my little acer,speeded it up considerable.
Same as with my laptop
I did 25% for OS, 20GB for a bit of storage, and the rest I have encrypted with TrueCrypt
I got a little confused. How the hard drive writes data? Starting from the inner sector and going to the outer or the other way around? So, if I'm formating a disk and I'll make partitions, the first partition that I'll create will be faster than the last or the other way around?
starts at the outer edges of each platter in turn, gradually moving inwards. The first partition is fastest.
Attached are 3 images. Don't have the old (full stroke) on my HDD, but It's a Western Digital Corp. Caviar Black 7200rpm 1tb.
http://www.newegg.com/Product/Produc...82E16822136284
Other two images are an external 1tb 7200 over esata...*
http://www.newegg.com/Product/Produc...82E16822149123
*just to show the performance gains of a similar drive @ full benchmark vs. short stroke (technically) the same RPM's/speeds (granted its 90mb/secish) access times diffeer between drives though :|
Don't have any graphs to show you, but yes, partitioning works effectively on traditional HDDs.
This is a non RAID array setup, by the way...
