1 - 13 of 13 Posts
I do not know what these settings at the top are. should i need to change these settings? i attached a pic. im overclock and is wonder if changing these will help. thanks.<br><a href="http://assets.overclock.net.s3.amazonaws.com/0/07/076de5aa_vbattach32580.jpeg"><img src="http://www.overclock.net/image/id/617551/width/525/height/525/flags/LL"></a>
You have it set to auto and I everything looks good if you FSB is 250 or less. The SB---NB HT Speed is you HyperThreading Technology that should be around 1000MHz of less. So if your FSB is 201-250 is should be 4x, 251-333 it should be 3X and so on. You HT Width seems like it is at a good setting, but the only way to make sure is to runs some benchmarks with different settings there and see what your results are.
thanks but why do i have to adjust the HT twice? i already adjust it in my overclock settings.
You are going to have to be more specific than that I am afraid. If I am understanding your correctly, totally unfamiliar with the BioStar bios by the way, you set your FSB, your cpu multiplier, and your HTT (HT) multiplier with "overclock settings". If that is the case that you set your HTT (HT) multiplier in another screen in your bios then you will not have to adjust it on that screen, but it appears to be set to auto and not manually adjusted.
Discussion Starter #5
heres the overclock settings.<br><a href="http://assets.overclock.net.s3.amazonaws.com/b/b0/b0a16267_vbattach32593.jpeg"><img alt="LL" src="http://cdn.overclock.net/b/b0/525x525px-LL-b0a16267_vbattach32593.jpeg" style="width:349px;height:312px;"></a>
Looks like you are good to go then. Like I said you settings look good as far as the Frame Buffer and HT Width goes, but playing around with some benchies is the best way to determine for your system specifically.
Reactions: luckii
Discussion Starter #7
oh sorry for being ambiguous. i posted the picture of my overclock options in my bios. i changed the HTT multiplier to 3x when i would overclock over 250mhz bus. but for some reason my computer wouldn't post. how you just told me that the SB to NB HT has to also be set to 3x. Now i can finally go past that 250x11 mark.<br><br>
basically, you helped me out alot with my overclocking. i thought something was wrong with my hardware when i wasnt able to get past 250x11. now that i changed the SB--HB HT speed, im at 2.8 and going to try past 3.0 =)
9 Cans of Ravioli
HT Width only helps when achieving higher HTT speeds. Takes a little bit of a hit on performance though. Most of the time the increased processor performance outweights it.<br><br>
euphoricmix; That is NOT his HT multi. And AMD doesn't have Hyper Threading. <img alt="" class="inlineimg" src="/images/smilies/rolleyes.gif" style="border:0px solid;" title="Roll Eyes (Sarcastic)">
Discussion Starter #9
here seems to be the highest clock on 11x.... 2.9 @1.5vcore. will test later. seems to be 34c on idle. since i have to the the NB<--SB HT speed to 3x if i go over 250mhz, will i also have to change the NB-->SB HT speed to 3x or keep at 4x?<br><a href="http://assets.overclock.net.s3.amazonaws.com/b/ba/ba65250e_vbattach32594.jpeg"><img alt="LL" src="http://cdn.overclock.net/b/ba/525x525px-LL-ba65250e_vbattach32594.jpeg" style="width:388px;height:505px;"></a>
Discussion Starter #10
heres memory settings, this ok?<br><a href="http://assets.overclock.net.s3.amazonaws.com/0/02/02f93366_vbattach32595.jpeg"><img alt="LL" src="http://cdn.overclock.net/0/02/525x525px-LL-02f93366_vbattach32595.jpeg" style="width:387px;height:505px;"></a>
Looks like you HTL indicating you HTT in CBiD is correct. I would assume those settings are being changed through you setting it to 3x with your overclock setting. At the very least everything looks in order and if it is performing as desired then I would leave it be.
On the HTT multiplyer/overall speed.<br />
Most MBs do up to 1040 safely, most actually can run @ 1080, but some can even excede the known 1080 wall. So if you get a little over 1000 as discribed above don't worry. Safe bet is 4x260 then drop to 3x above 260.
1 - 13 of 13 Posts
