Should I do It?
  • Buy Components
    Votes: 8 44.4%
  • Sell Existing Components
    Votes: 10 55.6%
1 - 14 of 14 Posts
I have a spare Asus Rampage Formula, Q9550 (Vid 1.12) and Zalman CNPS10X.
Now I was wondering should I buy a
-PSU $100
-G. Skill Ripjaws DDR2 1200
-5770 (Will Crossfire later)
Total will cost $357 shipped
I will put it on my Test Bench and buy a case later. Most likely Cooler Master Storm Scout.
Well should I do it? I have $1155 In my bank right now. I would hook it up to a 1080P 120Hz Samsung 40" LCD.
Or should I just sell the Asus Rampage Formula, Q9550 (Vid 1.12) and Zalman CNPS10x?
Well, it would be fun to game on a 40" TV, if you think you can spare the cash, go for it.
semi-legit
Keep whichever 9550 has the better VID and sell the rest
Originally Posted by getbigtony
buy! extra pc for TV is awesome
but why the expensive ripjaws?!
They are $15 more than the DDR2 1066 and they are already at DDR2 1200 (The max the Rampage takes)
Discussion Starter · #11 ·
Originally Posted by 2thAche
Does that Q9550 do 4.0+ ? If so I think you should just sell it. To me!
It does just cant remember what volts though.
It would be a cool machine to run to your home theater if you're interested in gaming on the big screen, or use a a secondary gaming rig if you have other gamers over. Otherwise it's kind of overkill for a home server or HTPC.
Sell and get something useful.
If you are doing this for a second computer, I think it is better to save and upgrade your current comp.
1 - 14 of 14 Posts
