1 - 4 of 4 Posts
As said in the title, which should I get? For this, since I'm buying whole system at retailer, the price difference is GS is $35 cheaper. Could you guys tell me the differences? Which overall is better?
Go for the GT if you dont plan to overclock because the GeForce 7900GS has the same number of processing units as the GeForce 7800GT, with 7 vertex shaders, 20 pixel shaders and 16 ROPs. Compared to 24 pixel shaders and 8 vertex shader in the GT. If you plan to overclock then 7900GS is great because its a killer overclocker. The GT is better overall because your buying for a retailer and you cant overclock with retail systems most of the time.
Definetly GT
nah wait for the geforce 8800 with DX10
1 - 4 of 4 Posts
