Should I get a dedicated RAID card?
1219 Views 4 Replies 5 Participants Last post by  XFreeRollerX
I'm thinking about going RAID 0, or maybe RAID 1+0.
Do I want/need a dedicated RAID card, or no? Any RAID knowledge would be appreciated.
1 - 5 of 5 Posts
Normally, I'd say the money the cost is totally not worth it. And even less for a PC, and not for a workstation.
I'd say, stay with your mobo integrated controller. The difference won't be THAT big. No as big as 400$.
Yea, especially since any difference between RAID controllers would be cheaper to just get a third drive.
You most likely won't notice any kind of performance boost unless you are using several SSDs.
For Two drives, no
For 4+ HDDS yes
Unless you're planning on RAID 1,5,10, etc, don't. Complicated RAID levels will place additional stress on CPU.. RAID card removes that stress to a dedicated controller
RAID 0, shouldn't even consider a dedicated RAID card unless +4 drives
1 - 5 of 5 Posts
