I would consider a Phenom II X3 720 instead. It will also work with your setup (since AM3 CPUs can work with AM2 systems), and later on when you get an AM3 motherboard and DDR3 RAM, you can use the 720 in that system.
Originally Posted by Penicilyn ![]() I too would suggest an AM3 cpu but not the 720. You can get a 955 for about the same money as the 940 you were looking at. http://www.newegg.com/Product/Produc...82E16819103674 By the way...how did you manage to get 7gig ram? |
