Should i get more ram or new ram
379 6
this is what i have now http://www.newegg.com/Product/Produc...82E16820148007 should i get another gig of this stuff or new ram all together,i dont realy know that much about ram havent learnd yet.
1 - 7 of 7 Posts
The ram you have is fine. It won't overclock with the best but its decent ram at an inexpensive price.
If you dont overclock, add another gig for some of the newer games (BF2, etc...).
It'll make a difference, especially in the newer upcoming games.
you could open your case and look and see what it says on the ram modules,then search online to see how good it is,and overclock you computer to improve performance...or if you dont want to OC then just run a cpu:ram divider to favor the ram example. 4:5
1 - 7 of 7 Posts
