1 - 9 of 9 Posts
I was looking at benchs and it performs better than the previous top dog, NH-D14. So should i get it? Im not really having problems with heat right now but it might help with OC, i have to keep my chip @ stock since it takes too much voltage to OC it at all, but i figure if i keep it colder itll OC better?
why can't you OC? have you tried to oc with it with the same voltages? Also I highly doubt it performs better although I haven't seen any reviews or benches, mind posting where you saw those?
I highly doubt the results would be the same on a processor with a higher TDP and overclock/overvolt.
Your processor won't overclock much better if it's just a few C difference in temps. You'll be able to squeeze a few extra MHz out of it.
Your chip probably requires a lot of voltage to overclock because one of the unlocked cores isn't perfect.
From a few reviews, this EVGA Superclock cooler can be an excellent performer. Coupled with a high speed fan, it surely can touch NH-D14. However, this all comes at the expense of the acoustic department as that single fan has to spin real fast. This downside might not be much welcome.
Discussion Starter · #6 ·
noise doesnt bother me, and even as an X2 it till cant OC.
Havent been in the air cooling game in a long while (since the TRUE was da boss) but to me this looks like a GREAT cooler at a GREAT price. It may be my next cooler tbch.
Discussion Starter · #8 ·
I will sell my CM 212 and get this, on ONE condition, if it supports push pull. If so then im getting it.
There are no holes for a second fan mounting clips on the cooler, but you could make something work with zip ties and/or tape if you're dead set on it.
1 - 9 of 9 Posts
