I would suggest not rasing the Vcore any higher and not going any higher than your current 240fsb, mostly because I see it's doing 43C, at idle I would guess?
As far as changing the timings, it would depend, if the modules can handle tighter timings they should work fine. Try 4-3-3-8 @ 2.1v-2.3v.
Other than that, it looks good.
