1 - 19 of 19 Posts
My specs are listed below, but i plan to get a 9800gt so would xp or vista 32bit be a better OS for me to run.
One more question
ok 1 thing i formatted xp yesterday and ive been getting these weird cpu spike. Out of nowhere my cpu would spike to 100% and it would just like hell including my sound. Only a restart fixes this problem. It happened 5 times already so what is wrong?
XP...
Less than 3GB of RAM is no go for Vista.
Initializing...
With that rig id stick to XP x86 then once you get 4GB of ram then get vista x64 or Windows 7 x64 once its out.
I wouldn't even give XP a thought. Go with Vista. I'd recommend the 64bit version, but if you really want 32bit still then that would be fine.
And if your worried spec wise put it this way, Desktop machines started running the 6150 Integrated chip for Vista. The ram though may be an issue, however I ran 2GB on Vista for almost a year and it worked out alright, not awesome but alright.
Also Vista will be better if you want to take advantage of the DX10 capabilities of that 9800GT you plan on buying.
Originally Posted by Lilxkid24
so even with a 9800gt stick with xp?
Graphics card is not what is important to run Vista... Even the crappiest DX9 card can run aero and stuff.
But the system is too bloated RAM-wise, so you need 4GB.
I actually like Vista, I began using it before SP1 and that was hell... Now Vista is a pretty acceptable system, RAM bloating being the only downside.
Yes if you are gaming, as stated above iv already ran vista with a dual core computer and 3GB of ram. I noticed a major slow down of load times for everything and even lower FPS in games.
Discussion Starter · #15 ·
Originally Posted by CallmeRoth
I trying going back to XP a few times when Vista was still shiny and I wanted to vomit. Now being on 7 I vomit when I use Vista. Old OS's and I don't get along well.
Ah ok, is 7 that good?
1 - 19 of 19 Posts
