Switch cases, or stick with what I have?
  • Keep it old school, stay with what you have.
    Votes: 6 27.3%
  • buy teh newesst 1337 case!!!!1
    Votes: 16 72.7%
1 - 20 of 28 Posts
I have my rig all setup now with my new water cooling and I was looking at it...and it's really a tight fit for everything. I was thinking I should buy a new case. What does everyone else think?
If I get a new case, it will have to have a few things no matter what:
-Lots of fan options
->=4 5.25" bays
->=6 3.5" bays (internal + external)
-Have room for a 9.5" long X1900XT, and an equally long Tidewater
-Window!
Extras I want:
-Blowhole fan
-Upsidedown ATX motherboard tray
-Two power supply mounts
-Case under or about $150
I say if you can buy it, GO FOR IT!
Discussion Starter #6
Originally Posted by biatchi
what about the mozart tx if you gots the dollar for it
I like the case, but I would not use all of it, plus the case needs to fit on my desktop. An upsidedown ATX motherboard tray/case would allow me to put the case against the wall and still have a window.
"Darling you gotta let me know
Should I stay or should I go?
If you say that you are mine
Ill be here til the end of time
So you got to let know
Should I stay or should I go? "
Anyone think of the Clash ?
Discussion Starter #8
Rep point for getting the title
Yes
Hehehe you said blowhole.
I would go for the new case if you have money to spare for it. You can trick it out and make a build log with it.
Stacker FTW....
but, it doesn't have the upside down ATX though.
Discussion Starter #12
Yes
Wow
you really do need a new case. It's packed like a can of fish in your case. Speaking of fish...lol blowhole.
Discussion Starter #14
I have 11 fans in there hiding ^_^ It does keep good temps though...my cpu is 80F right now, thats a bit under 27C.
Originally Posted by BrinNutz
Stacker FTW....
Its a mirrored case though, so you could flip it and it would work out just fine.
Here is a good price on a Stacker.
http://www.svc.com/stc-t01-ubk.html
And a clear side panel for it.
http://www.svc.com/rc-880-wkn1.html
EDIT: Oh and "all you do is take take take."
pink
Discussion Starter #18
I hated the armor until I went in and looked at it in store. If the little door things come off, I would keep it in mind for a new case. I'm also looking at the p180b and the 900.
p180 is small for you. just get the 900
Yea the tidewater would not fit in a P180 due to the wiring config. However the Stacker I linked can be fliped to have the opening on the other side so it will work in the config you want and does allow for two PSU's.
pink
1 - 20 of 28 Posts
