1 - 14 of 14 Posts
I have a chance to get an i7 bloodrage combo???
should i?? (I feel like such a tratior)
The problem is i have only air cooling. I got the 955 thinking i was gonna break 4ghz. I cant get water because the misses will notice the new setup. I can however swap cpus and mobos etc....
I found a cheap deal on the i7/bloodrage
what would YOU do????
Yes, I have heard/read great things about them. I am buying everything in my sig if I don't buy a drag car in the next week.
Data Recovery Engineer
Unless you do some heave multitasking I do not see the need for an i7. What you have is an awesome setup and I say you should keep it.
Efficiencycionado
if it's for the same price, then get it.
and enjoy watching that filthy intel company get rich while poor amd rot.
just kidding
If you do encoding or other heavy multi thread tasks the switch could do some good. If not you will see no difference. But if its for the same price do upgrade because i7 is a great deal faster in multi thread optimized programs.
Discussion Starter #6
just kidding
Right in the gut......
Yea its hard but i want my bits nice 'n' thight you know?
and that i7 looks reeeeeel nice
plus if what they say is true i can get the 6 core and keep the bloodrage
Don't worry about disgracing AMD if a certain processor does a better job at a certain price than get it.
IMO go with the i7.
Your wasting almost half of your ram with 32 bit.
Discussion Starter #9
send him a pm DIS MY THREAD!
Power Squid
Do it.
Discussion Starter #14
Originally Posted by amay200
I would recommend you do not swap... simply on the grounds of having to hide this from the misses...
DUDe.............
I'm not gonna and try for a water cooling system
I mean you only live once right.....right?
1 - 14 of 14 Posts
