1 - 20 of 22 Posts
Somebody has offered me a trade on my GTX580. Two Twin Frozr GTX470's.
Now financially, this seems silly. GTX580's are still $400 or more, and 470's are around $150-175 each. But the dual 470's would perform a lot better.
I have no cash, no I'm not buying another 580 anytime soon.
What do?
Personally, I don't think the switch to SLI 470s is worth it. you're throwing some money away and dual-GPU set ups can always be hit or miss. In games like GTA4, you'll see a performance drop, possibly even larger than with just one 470.
Keep the 580 its a much better card.
keep the 580
I would keep the 580. Having sli 470's is nice (see sig rig
) but selling them currently is a pain, because they are considered last generation. Even though they perform just as well as the 5XX series.
If the guy trades you plus adds in some cash I can see doing the trade.
On a financial basis, if it is two GTX470 Twin Frozr + (say) $75 for your GTX580, then it is 'fair'.
On a performance basis, if you are just a little unsatisfied with your GTX580, then I say you bear with it. You do not have cash now and will not be able to buy a second GTX580 anytime soon but you will sometime in the more distant future. By that time, your dissatisfaction will have grown more but it will be done away with as you will have money then.
If you are highly unsatisfied today already, then I suppose you to do the trade but negotiate for that extra $50 or $75.
Discussion Starter · #15 ·
I was honestly more than satisfied with a single GTX470 until I killed it.
This GTX580 is already overkill for all the games I play. Well, except Crysis of course. So no, I'm not unsatisfied in the least bit.
I'm just bored with my setup as it sits. I've got NOTHING to tinker with!!!
I'd only take the SLI 470 GTX's if he chipped in 75-100$. just let me check if you will get a slight performance gain - YES, You should totally trade the 580 for the SL 470's and a bit of cash. Here, If you'd like to check it for yourself, you can see a total performance upgrade:
http://www.gpureview.com/show_cards....637&card2=628#
Hopefully you get those cards, + 50-75$!
EDIT: - Hit the Multi-GPU Button under the GTX 470 side - Then it will show you the specs of dual-cards.
Discussion Starter · #17 ·
If I were to do the trade, he won't be adding any cash at all. His cards are Twin Frozr's, and mine is a marketing sample or something from EVGA with no warranty.
Was told though, that my PSU won't handle the 470 SLI by a reputable PSU guy. So looks like my choice is made....
LOL...then no need to mess with the GTX580.
Poke your fingers at other parts of the system. But I see your rig is fairly well balanced. Perhaps you can get yourself wet. Watercooling will definitely kill off a lot of time.
Short of doing a custom loop, perhaps consider using a Corsair H100 to replace your Xigmatek. This will not be just for time killing but also will bring tangible benefit (eg getting your i5 2500k to 5GHz).
Discussion Starter · #19 ·
I'm already planning on getting wet. Saving for a full loop with the 580 in it. 240 + 120 rads, because I also plan to go smaller too.
Woot, GTA 4 runs flawless on a single GTX 470 at 1080p.
I wouldn't trade it though. The 580 is more than enough for current generation games and you always have to wait for drivers for performance improvements or SLI support.
1 - 20 of 22 Posts
